| Custom DeLoreans / Mods Discuss anything relating to custom DeLoreans and mods. Be sure to check out Rich's sub-forum below. |
Thread Tools | Display Modes |
#11 | |
Legend Twin Turbo AND VQ35. Wanna race? :)
![]() ![]() Join Date: Apr 2005
VIN: 01860, 03965, 06068
My Club: DMA, DCS
Why would someone do that to ME?? I am so well liked.
"Can't you see. It all makes perfect sense. Expressed in dollars and cents, Pounds, shillings and pence. Can't you see It all makes perfect sense." DeLorean Car Show, Serving *ALL* DeLorean owners and enthusiasts on the planet - http://www.deloreancarshow.com/ See you in Lexington June 17-20 2010! |
#12 | |
![]() ![]() Join Date: Jan 2005
My Club: DCF
Former owner of Vin 6720 Next Car, possibly Twin Turbo 300ZX |
#13 | |
My Club: DMA, DCS
Derek Bell in the UK has a number of performance parts that will work in our transmissions, including a one-piece input shaft. It is the coupler on the input shaft that is usually the first thing to break. Another option is Toby (DPNW, now DMC-NW) who has a replacement (stronger) coupler that he sells. These items will raise the max HP/Torque the gear box can handle but at some point something else will give. Some say that the coupler is a "fusible link" in the trans, to protect more expensive parts. Either way, when I investigated the route of beefing up the stock Renault transmission, the cost was incredible! And that was back when the US/UK exchange rate was not as bad (for the USA) as it is now. It was a bit more work, but turned out to be less expensive to go with the Porsche 915 box. Even though Porsche is expensive, it was still cheaper than the alternatives. There are also lots of Porsche resources in the USA, not so much for Renault. The most expensive single component of my VQ35 swap was the transmission. It also added some interesting problems to solve. Tom and I spent more time trying to work out the transmission issues (Placement, level, shift linkage, clutch setup) than the engine. If we could have used the stock Renault box, the swap would have been much less complex. If you are staying under 300 HP, it may be worth while to have a custom adapter or bellhousing made to mate the VQ to the Renault box. One of the problems you will have is the short input shaft. I had a few ideas on how to solve that problem, but decided to go with the Porsche setup because there was a ready-made adapter I could buy to mate the VQ to the Renault. The up side is, I can potentially add lots more power to my car (with more money) and not worry about the 300HP limit.
#14 |
![]() ![]() ![]() ![]() Join Date: Jan 2005
you are so right about the tranny. upgrading the UN1/369 renault tranny is way more than getting a porsche one. I found a very rare g50/50 turbo transmission with LSD for a realy good price. The going rate for those are 7K to 12K. They can handle 800hp just fine. The regular g50 transmission is good for 450hp. porsche is the way to go for the price. The only thing i did not like about the 915 tranny is the problems they have with syncrose going bad.
GO BOOST OR GO HOME!!!!! |
#15 | |
My Club: DMA, DCS
#16 |
i'm hopping that will go to my advantage because of the high inline 6. i've got my plasma cutter and welder ready!
from these pics it looks the same to me. http://www.motormeister.com/suz/trans/clutch_trans.htm
GO BOOST OR GO HOME!!!!! Last edited by 82DMC-12; 07-02-2008 at 06:51 PM. |
#17 | |
My Club: DMA, DCS
The 90deg PRV is a very short engine, even with that mess of an intake. Engine placement will depend on where the trans fits for the drive axles to line up. Once you get the trans set, you are stuck with where everything else ends up!
#18 |
I plan to make the trany to engine fitment as short as possible. I'm planning on using the bellhousing from the supra tranny and cutting and welding the two together.
This is why i love this engine. http://videos.streetfire.net/video/Fast-Supra_71278.htm
#19 | |
My Club: DMA, DCS
either way, I think you may have a height problem.
#20 |
No one makes an adapter, i already asked all the companies.
I did some measuring from my buddies engine and i've got plenty of room with a few inches to spare. He has a 240sx with a 2jz, and that thing will put you back in your seat to the point you can't pull your self forward.
| swap, vq35de |
| Wheel swap | TEXSIX | Custom DeLoreans / Mods | 2 | 04-20-2008 07:28 PM |
| Possible Engine Swap? | bluxed | General DeLorean Discussion | 11 | 07-07-2007 12:20 PM |
| Seat swap out | JBaker4981 | Custom DeLoreans / Mods | 6 | 10-14-2005 02:37 PM |
| Possible Radiator Swap | dmc-4359 | General DeLorean Discussion | 21 | 08-26-2005 10:51 AM |
| engine swap | smallclone | General DeLorean Discussion | 22 | 08-21-2005 06:08 PM |
