| Resources Technical Documents, Schematics, Diagrams and other resources for owners. |
This takes someone good making a proto-type to fit inside an old relay case but you could make it longer. This unit will produce no heat and the contact resistance will always be 0.003 ohms. My unit is installed and working as expected.
#2 |
Solid State Lambda Relay
-------------------------------------------------------------------------------- This takes someone good making a proto-type to fit inside an old relay case but you could make it longer. This unit will produce no heat and the contact resistance will always be 0.003 ohms. My unit is installed and working as expected.
Dave M vin #03572 Last edited by Ilan; 11-13-2007 at 01:00 PM. |
![]() Join Date: Oct 2009
VIN: 16409
Dave, how much do you charge for this relay?
Chris For Better or Worse I own a DeLorean! 1983 Grey Manual, VIN #16409 Fresno, California |
#4 |
I never brought these to production. I could not sell enough of them to break even on my cost to make it a production item.
Dave M vin #03572 |
| lambda, relay, solid, state |
| Solid State Main/Aux Relay | Bitsyncmaster | Resources | 4 | 09-30-2007 03:03 PM |
| Solid State Main/Aux Relay | Bitsyncmaster | Custom DeLoreans / Mods | 0 | 02-14-2007 12:47 PM |
| Solid State Lambda Relay | Bitsyncmaster | Custom DeLoreans / Mods | 8 | 02-09-2007 07:24 AM |
