Go Back   DMCTalk.com forums - A DeLorean Community > Main Forums > General DeLorean Discussion > Resources
Register Blogs Calendar Mark Forums Read
Resources Technical Documents, Schematics, Diagrams and other resources for owners.
Old 02-14-2007, 12:47 PM   #1
Bitsyncmaster
Bitsyncmaster's Avatar
VIN: 03572
Default Solid State Main/Aux Relay
I now have the three relays that are needed to run the engine solid State. I may also do the Aux Relay since it is the same as the Main but I think I will stop there and move on to something new.
Here is the design of the Main. A little overkill using three FETs but I still get no heat at all even without heat sinks.
Main_relay 001.jpg   Main_relay 002.jpg   Main_relay 003.jpg   Main_relay 004.jpg   Main_relay 005.jpg
Dave M
vin #03572
Bitsyncmaster is online now   Reply With Quote
Old 09-29-2007, 10:14 AM   #2
rhd_delorean
rhd_delorean's Avatar
Default Re: Solid State Main/Aux Relay
This is an interesting update, might try to do a few myself.
Is there any disadvantage for using such relays?
Kind Regards.
rhd_delorean is offline   Reply With Quote
Old 09-29-2007, 10:33 AM   #3
DMCMW Dave
DMC Midwest
DMCMW Dave's Avatar
VIN: 5429 + a few others
My Club: DMidwest
What's the forward valtage drop through the FETs?
Dave S
www.dmcmidwest.com
DMCMW Dave is offline   Reply With Quote
Old 09-30-2007, 01:38 AM   #4
Bitsyncmaster
VIN: 03572
I have had these FET relays and my solid state RPM relay in my car since.
Have not had any problems.
The voltage drop through a FET is computed by ohms law since the FET is just a swiched resistor. Most FETs are fully turned on with 10 volts on the gate to source. The data sheet then specifies the resistance at this point.
Ohms law.....E=IxR....or volts equal amps times resistance.
The IRF2204 specifies a typ. 3.0 mOhm.
10 amps = 0.03 volts
30 amps = 0.09 volts
Now you can compute the heat that needs to be disipated by the FET.
P=ExI....or power equals voltage times amps.
@10 amps = 0.3 watts
@30 amps = 2.7 watts
Now you see why I used three FETs for these high current relays. It's not the voltage drop but the reduction in heat....so I don't need heat sinks. Three FETs now give me 1.0 mOhm. so power disipation @ 30 amps drops to 0.9 watts.
I'm now running out of things to do to my D and I plan to replace my FANZILLA with a solid state unit next.
Dave M
vin #03572
Old 09-30-2007, 03:03 PM   #5
bmdmc
bmdmc's Avatar
Oh no, I have a better project for you, check your PM.
Bernie
Owner VIN 4045 and 6704
1979 Camaro
2006 Dodge Charger SRT8 (SOLD)
2009 Dodge Challanger SRT8
No trees were killed in the sending of this message, but a large number of electrons were terribly inconvenienced.
bmdmc is offline   Reply With Quote
main or aux, relay, solid, state
Solid State Main/Aux Relay Bitsyncmaster Custom DeLoreans / Mods 0 02-14-2007 12:47 PM
Solid State Lambda Relay Bitsyncmaster Custom DeLoreans / Mods 8 02-09-2007 07:24 AM
So you think you know everything... mauibarber Open Discussion 15 06-13-2006 05:04 PM
My car died out of no where! HELP!!! nofear365 General DeLorean Discussion 40 11-10-2005 06:14 AM
LONG! Electrical experts: Fan relay wiring help needed BAD at88mph General DeLorean Discussion 8 09-26-2005 11:22 AM
