| How-to Guides Detailed, step-by-step instructions about various Do-it-yourself projects. |
#11 | |
![]() ![]() Join Date: Jun 2005
http://www.delorean.com/store/c-294-...t-linkage.aspx all you should have left to do is take the 8mm nut off (part number 1) and remove the mounting bracket (part number 3 and there's also a spring under it; part number 10) and once you remove that, the bottom of the shifter will come out. At the back of the base, you'll see two phillips head screws, unscrew them and gently start to pull the base up watching underneath it for all the wiring. To make it easier, you can remove the 3 a/c knobs and there is a small screw that is located there to remove the a/c panel. This isn't really necessary, but does make it a little easier to remove the base. If your removing the base completely, make sure you mark/remember how the wires to the dimmer switch goes. Hope this helps.
'81 DMC w/ Chevy 4.3 Votec and Porsche 915 transmission Last edited by at88mph; 04-04-2008 at 09:23 PM. |
#12 |
![]() Join Date: Sep 2007
Is there a description of the procedure for removing the body from the frame?
#13 |
Must resist spending impulse...
![]() ![]() ![]() Join Date: Mar 2007
VIN: 1601; Formerly 6982
My Club: DMidwest
I'm surprised there's nothing about removing the front fenders. I have a dent in the front left that I should be able to hammer out if I can get the fender off the car.
-Chad K. License plate: "DRACULA" DeLorean owner since 2006. Easily distracted by shiny things. My DeLorean IS my reliable, daily driver. |
#14 |
Formerly CSMCGRN
![]() ![]() Join Date: Oct 2007
My Club: NCDMC
Request, how to test spray pattern for fuel injectors. thx
#15 |
My front suspension sounds like it has arthritis
![]() ![]() ![]() Join Date: Jul 2005
VIN: 10084
My Club: DCF
-Derek #10084 http://www.deloreanreborn.com - Weblog detailing my car's rejuvination http://www.deloreanclubfl.com - Florida's home for DeLorean enthusiasts |
#16 |
Spooling...
![]() ![]() ![]() Join Date: May 2004
VIN: 1776
I hate to be a whore, but might someone be kind enough to post on how to replace an alternator? I think mine might be going bad, and will need to be replaced. The battery light keeps flashing intermittently during highway driving, and I don't think it's the battery.
I may buy a Hervey alternator, I assume you can get the correct belts from him? Last edited by Hollywood2311; 06-15-2008 at 06:43 PM. |
#17 | |
http://www.dmctalk.com/showthread.ph...one+alternator |
#18 | |
VIN: 10084
My Club: DCF
Here is a quick install walkthrough. Its not hard at all, but aren't you running an Eagle Premier? That may be different. http://www.dmctalk.com/showthread.php?p=124176
#19 |
Formerly CSMCGRN
My Club: NCDMC
Request How To
How to properly adjust parking brake cables and pads. Thanks I searched and didnt really find a how-to. Several posts, but not one complete. This topic is also not in the service manual.
Northern California Delorean Motor Club WWW.NCDMC.ORG Your source for Synthpop and Electro Music- www.adifferentdrum.com |
#20 |
VIN: 4699
Would like to see a how to on adjusting the shift linkage on a 5spd. Maybe some good pix. That would be sweet.
| howto, list, request |
| LED list for the whole car. | DeLorean03 | Custom DeLoreans / Mods | 186 | 04-23-2010 06:42 AM |
| LED list update!! | Morpheus | General DeLorean Discussion | 81 | 11-11-2007 08:54 PM |
| DMCForum | Chuck McKnight | Open Discussion | 102 | 07-20-2006 04:51 PM |
| dmcnews.com vin list | GMarqDelorean | General DeLorean Discussion | 2 | 08-02-2005 05:33 PM |
| Vin list updated | CalSteve | General DeLorean Discussion | 4 | 07-12-2005 11:00 PM |
