Go Back   DMCTalk.com forums - A DeLorean Community > Main Forums > General DeLorean Discussion > How-to Guides
Register Blogs FAQ Calendar Mark Forums Read
How-to Guides Detailed, step-by-step instructions about various Do-it-yourself projects.
Thread Tools Display Modes
Old 12-11-2006, 08:56 PM   #1
Beachdrifter
Beachdrifter's Avatar
Lightbulb How-to: Eibach Rear Springs Removal/Reinstallation
Hey guys,
This X-mas break I will be installing Eibach Springs in my car. I figured I would document my experience and take pics for all to see. This is my first time doing anything like this on any car, so I am a newbie, and hope this helps other newbies.
I will explain what I have done, and if anyone else has recommendations feel free to post.
So far I have started and finished only the rear passenger side spring.... so here we go:
^^^ First, jack the car up as you would normally. Always use jackstands. I rented spring compressors from AutoZone, and put them on the old springs as shown in the pic. A good rule of thumb is to get the compressor span-range to 4 coil rows to sufficiently compress the coil.
I also sprayed a lot of PB Blaster on the nuts to ease removal.
Compress each side alternating to have even compression. Once the coil is compressed to the maximum ability of the compressor, begin to loosen the nuts above the shock tower. Then loosen the nut below the strut.
BEFORE removing the strut, replace one of the nuts on the top shock tower to keep the strut assembly in place while you free the lower strut from the bolt.
It was useful to use the jack just below the strut as I freed the lower strut. This will prevent the strut shooting out with residual spring tension and the jack will "catch it"; this will allow you to slowly lower the strut.
^^^ Once the strut is loose, you can take the strut apart. Very simple. Notice how compressed the spring is. Uncompress the spring.
^^^ Here is a great pic to show the uncompressed springs by comparison; stock vs eibach.
^^^ Reassemble the strut assembly and compress the new spring. (Notice I did not use the 4 rule of thumb; my mistake, as I corrected this later. In this pic I used 3 and it was not enough to sufficiently compress the spring)
^^^ Again, use the jack to aid you in lifting the strut assembly into place, especially while you hammer in the bolt through the lower strut. You will have to play around with this part and jiggle it through. Spray some PB blaster on the bolt to make it go through the hold easier.
^^^ Here is a good pic of the strut assembly and compressors. Notice the compressor spanning 4 rows on each side. Once the strut assembly is in place, uncompress the spring, each side alternating. The spring should sit nicely and fill the entire shock tower when uncomressed.
^^^ Once it is in, and fully uncomressed, tighten the lower strut nut and also the upper shock tower nuts. You may have to use the jack to jack up the strut to reinstall upper nuts again.
And voila, it is done.
_______________________
Ok, I did not use any power tools and it took me 4-5 hrs to do one spring. Granted I have never done anything like this before, so I am hoping the next one I do tomorrow will go quicker.
I am not sure if I am going to tackle the front springs myself or not, but we'll see.
When all is done I will show pics of the car and show how it is lowered.
Please, use this procedure at your own risk. I am not responsible for damages or injuries that may occur to you. This is what I did to my car and it worked fine. Keeep in mind that compressed springs are very dangerous. Take your time, be safe, and do not rush!
Hope you guys enjoyed this post. I will do the drivers side rear tomorrow. I will update this thread with pics as needed.
--Randy
[#5945 - FrankenDeLorean] Oct. 31, 1981
Melbourne, FL, USA - The Space Coast.
"A wave is like an empty canvas, waiting for a masterpiece."
Beachdrifter is offline   Reply With Quote
Old 12-11-2006, 09:19 PM   #2
Hollywood2311
Spooling...
Hollywood2311's Avatar
VIN: 1776
Default Re: Eibach X-MAS Project -- DIY w/pics!!
*edit* Nevermind, you did the rears...
Signed,
Eric C
VIN #1776
Hollywood2311 is offline   Reply With Quote
Old 12-11-2006, 09:47 PM   #3
mark v
Uh.... stock springs are not red.
mark v is offline   Reply With Quote
Old 12-11-2006, 10:26 PM   #4
Ilan
Ilan's Avatar
My Club: DMidwest
Thumbs up Re: Eibach X-MAS Project -- DIY w/pics!!
Pictures don't seem to work for me. Can you upload them here?
Edit... must have been geocities as they're now ok.
Nice write up.
Ilan is offline   Reply With Quote
Old 12-11-2006, 10:35 PM   #5
Hollywood2311
Spooling...
VIN: 1776
*edit* and they work again. Haha
Signed,
Eric C
VIN #1776
Old 12-11-2006, 10:44 PM   #6
BrianP
BrianP's Avatar
VIN: Former Owner
Are those original shocks?
- Brian
BrianP is offline   Reply With Quote
Old 12-11-2006, 11:01 PM   #7
DMage
My front suspension sounds like it has arthritis
DMage's Avatar
VIN: 10084
My Club: DCF
Some of the pictures are not working. Randy, thanks for taking the time to do this writeup, maybe I'll rethink about doing this myself when I get around to it...
-Derek #10084
http://www.deloreanreborn.com - Weblog detailing my car's rejuvination
http://www.deloreanclubfl.com - Florida's home for DeLorean enthusiasts
DMage is offline   Reply With Quote
Old 12-11-2006, 11:04 PM   #8
Beachdrifter
I'm assuming they are originals. But i will remove the pics off the geocities site and use an image dump place ..not enough bandwith. Sorry guys.
--Randy
Old 12-11-2006, 11:06 PM   #9
Way of Cain
Way of Cain's Avatar
VIN: </2835>
Wasn't that Chrome's car in a former life? If so, color doesn't mean anything as to what is stock or not.
Way of Cain is offline   Reply With Quote
Old 12-11-2006, 11:10 PM   #10
mark v
Ahhh.... True. Chrome colored everything he could touch.
eibach, howto, rear, removal or reinstallation, springs
Lowering Springs TheSmokingMan Custom DeLoreans / Mods 34 04-19-2006 06:41 PM
Wanted!!! Springs Rear Seats! tk_1485 DeLorean Parts 25 01-06-2006 01:52 PM
How to remove rear storage wall/shelf? DMage General DeLorean Discussion 6 09-13-2005 04:44 PM
LED rear lights - Update!! rhd_delorean General DeLorean Discussion 19 06-19-2005 05:17 PM
HELP! DeLorean rear speaker location Dave1982 General DeLorean Discussion 2 06-09-2004 02:05 PM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
