Go Back   DMCTalk.com forums - A DeLorean Community > Main Forums > General DeLorean Discussion
General DeLorean Discussion Tech help and certain general discussions of the DeLorean, DeLorean Motor Company, and John Z. DeLorean.
Old 03-17-2010, 06:41 AM   #1
Brisfx
Brisfx's Avatar
VIN: 6380
Default Starter Motor
Hi
My starter is toast and I am looking for a new one. Just wondering if there is one that I can buy here in Australia to save on postage of such a heavy item. Is there a Volvo or Renault one that fits?
Brad
Brisfx is offline   Reply With Quote
Old 03-17-2010, 09:31 AM   #2
jtrealty
Delorean Guru
jtrealty's Avatar
VIN: 10757
My Club: DMA
Default Re: Starter Motor
Most of the time they are rebuildable. If the armature or the field is burnt it is sometimes cheaper to get another. The starter seems to be almost bullet-proof in the Delorean. It has a very low failure rate. I would have it tested to be sure it's bad.
David Teitelbaum
jtrealty is offline   Reply With Quote
Old 03-17-2010, 10:39 AM   #3
Matthew
Matthew's Avatar
I prefer the one from the Eagle Premier/Dodge Monaco. It's also smaller and thus, a little easier to install. It will draw more current than the stock starter, however. No modifications necessary.
Matthew is offline   Reply With Quote
Old 03-17-2010, 03:23 PM   #4
dmc-5180
Junior Member
VIN: 5180
My Club: DMC(Chicago) & Mid-State
This picture is of a starter that will NOT directly bolt on. Unless there are some factory bolt lugs in the Block I'm not seeing. The other thing is that it appears this starter would bolt on to the opposite side of the engine. Unless the picture is somehow (reversed) I have seen that before.
Dennis
Stage I, Eibach Springs, SPAX Adjustable Shocks, Adjustable Lower links,DPNW Poly ARB Bushing kit,DMCEU LCA support kit, HID Sealed beams. The Latest enhancement DMCMW ILLUMINATED DOOR SILL'S
I'm not Cheap, I've spent thousands of $ on my D !! I know where my priorities are!!!
dmc-5180 is offline   Reply With Quote
Old 03-17-2010, 03:31 PM   #5
Farrar
owner of "Sparky the AutoCarb"
Farrar's Avatar
VIN: 2613
Yeah, that looks weird to me, too. When I go to AutoZone's website, plug in 1991 Eagle Premier and look at the starter motor, here's what I get.
Is there an AutoZone in Australia?
Farrar
Farrar is offline   Reply With Quote
Old 03-17-2010, 08:08 PM   #6
dmc-5180
Junior Member
VIN: 5180
Farrar
Much Better and rather intriguing to see the smaller motor. Looks like a nice unit. I wonder if they require a core?
Dennis
Old 03-17-2010, 06:24 PM   #7
Matthew
Matthew's Avatar
Oops, you're right! Wrong pic!
Old 03-17-2010, 10:50 AM   #8
jmettee
Living the Dream since April 20, 2008
jmettee's Avatar
VIN: 2075
My Club: DMCMD, DMA
From the resources section, emergency cross-over list:
Excel or Lester: 17019
Also, looking online, I also found BBB PRECISION Part # 17019
Never heard of any of those brands.
Meanwhile, Volvos using the same engine have a different starter specified (& more options). I guess the starter is unique to the D for some reason, possibly due to fit? Maybe someone can answer this.
Justin Mettee
VIN 02075, June 1981 Build
Treasurer, DeLorean Mid-Atlantic
jmettee is offline   Reply With Quote
Old 03-17-2010, 01:38 PM   #9
Farrar
Farrar's Avatar
VIN: 2613
On the DML a little while ago someone mentioned that the starter for a 1991 Eagle Premier was a bolt-on replacement. Not sure where you'd get one, though.
Farrar
Old 03-17-2010, 01:58 PM   #10
DMCMW Dave
DMC Midwest
DMCMW Dave's Avatar
VIN: 5429 + a few others
My Club: DMidwest
Farrar
Especially in Australia. Not sure they sold a lot of Eagles there. . .
Dave S
www.dmcmidwest.com
DMCMW Dave is offline   Reply With Quote
starter
[Electrical] Now my starter isn't working... again. AdmiralSenn General DeLorean Discussion 26 11-26-2009 06:06 PM
[Electrical] Help with sourcing a starter DMCMON General DeLorean Discussion 12 09-20-2009 10:54 PM
[Electrical] Starter Motor Heat Shield Brisfx General DeLorean Discussion 1 07-13-2009 07:09 AM
starter troubles Lamboman General DeLorean Discussion 5 03-15-2007 12:34 AM
Telltale sign of shot starter motor? DMage General DeLorean Discussion 19 11-13-2006 06:02 PM
