| General DeLorean Discussion Tech help and certain general discussions of the DeLorean, DeLorean Motor Company, and John Z. DeLorean. |
New Member
I intend to fix the analog controls, but this has given me an excuse to buy a digital meter as well...Dakota Digital said if the speedo cable was similar to a GM one I could use this device http://www.dakotadigital.com/index.c...prod/prd57.htm in parallel so I could do both the electronic signal and keep the analog. Anyone know if this works or if the delorean speedo cable is like a GM one?
#2 |
VIN: #6513 black D
My Club: DCN
Are you sure it's the speedo/odo that died or just the cable that won't turn any more (angle drive defect..., stuck upper cable)?
I'm in the process of replacing the angle drive with a HAL and electronical-to-mechanical drive. If that works out, you can still use the upper cable and original speedo/odo. This will be as costly as replacing the current system with the dakota digital system. BTW having a speedo/odo repaired and calibrated is not that expensive. The option you're offered by DD now will turn out to be more expensive than repair. Welmoed.
DCN #261 black VIN 06513 Pontiac TransSport V6 3.8L |
New Member
I agree it's probably just a broken cable, but I intend to replace the whole system...as you said, it's pretty cheap. I just wanted a digital one as backup (and it looks cool). I've seen a speedo cable that's really long and eliminates the service counter box..might just go with that
| speedo, speedometer, speedometer cable |
| BLAH it just died | AirmanPika | General DeLorean Discussion | 8 | 08-27-2008 03:56 PM |
| My Xbox died? | BenDutta | Open Discussion | 17 | 05-22-2008 07:30 PM |
| Mr. Wizard died today | qumefox | Open Discussion | 5 | 06-13-2007 09:11 PM |
| My car died out of no where! HELP!!! | nofear365 | General DeLorean Discussion | 40 | 11-10-2005 06:14 AM |
| HELP! MY D DIED | delorean6969 | General DeLorean Discussion | 25 | 12-01-2003 01:34 PM |
