| Custom DeLoreans / Mods Discuss anything relating to custom DeLoreans and mods. |
#1 | |
I would love to hear your thoughts on why my car was sitting so high after installing Rob Grady's front lowering springs (stock rear springs). Take a look at this video and skip to 2:24. Note that in this video, none of the suspension bolts have been tightened or even threaded more than 2 or 3 threads - not even finger tight. There are polyurethane bushings all around, and the gas tank is near empty. If the springs don't need to settle, I don't know what else it could be. 6 months later, without tightening any bolts, and without moving the car, it sits noticeably lower. I will post pictures when I can. This video is from July 25, 2009. |
#2 | |
Owner
VIN: 03441, 03307, 06147, 04523, 00021, 11485
My Club: DCO, DOA
My experience with various Deloreans, various spring kits (including Grady's), & various bushings is no "settling" after installation. Properly designed springs for a given application should not "settle". If they do, they have been stressed beyond their design load yield point into the plastic (non-linear) region where deformation occurs (will not return to the original dimension). I need to finish up my Delorean spring testing project and article - Ken Koncelik has been bugging me to have it ready for the next (last?) issue of DCS Magazine. Lots of interesting observations..... Cliff |
Junior Member
I can putt some extra info to this, if you remove the foam bumper on the front.
You will see a orange sticker with a number, this is a indication on the body mould that was used. The difference was real big, so they did mark the body’s. If you use one size of springs you will see there is more thane 2 inch difference in height. The factory did use 2 type off springs one set has yellow and the other has red paint. This was to compensate the difference, so with lower springs you will see still difference between the cars. A normal spring will stay on it height, if it lowers you have a bad spring. Retune it to the supplier, A spring that lower it self well not stop lowering. We did see lot off uk springs go bad and even brake. (I not speak a bout Martin his springs). With this I have no experience. Regards Ed Uding www.delorean.eu
I drive it my way |
#4 | |
formerly Stunned Monkey
VIN: 4772, 3352 - ex 4748, 1458, 4426, 11766, 1484
![]() I had mine made simply because I too kept seeing springs that had sagged or broken. However, springs -do- settle a little over time. Mine carry instructions to torque with weight on the car, and to loosen and re-torque after a certain period - this is to release any pre-load in the bushes as the springs settle. |
#5 | |
Defying the $20k rule
VIN: 1768
i dont quite understand thiss, when i took my front end apart i found no stickers, also my front endi is about 1" high than most stock cars |
#6 |
DeLorean Owner/Aficionado
It *should* be behind the foam bumper behind the front fascia. Did you remove that portion too?
Patrick C. Vice President, DeLorean Club of Ohio VIN 1880 See my polished stainless finish==> http://www.youtube.com/watch?v=Us02zx86KYQ http://www.cardomain.com/ride/2239767/1 |
#7 |
http://i111.photobucket.com/albums/n...o/eae84f2c.jpg
http://i111.photobucket.com/albums/n...o/31cea750.jpg This is my car after sitting 7 months. Sorry i couldnt format properly. Im on my iphone. |
#8 |
VIN: 1768
#9 | |
Owner
My Club: DCO, DOA
tnx, Cliff |
| lowering springs, shocks, suspension |
| Eds front LCA mod***Split from Legend thread*** | DMCEU Ed | Custom DeLoreans / Mods | 89 | 04-07-2010 08:21 PM |
| Chat time with Marc and Bill***Split from Stock Lug nuts vs Gorilla thread*** | malevy | Open Discussion | 42 | 02-10-2010 09:43 PM |
| Random Oil chat ***Split from Pure Power Thread*** | dmc-5180 | Open Discussion | 16 | 11-10-2009 02:09 PM |
| Chit chat from want to buy thread - Norwegian talk | Funkmasterbrad | Open Discussion | 9 | 02-25-2008 09:57 AM |
| Chit Chat from Tinting Back Windows thread | smallclone | Open Discussion | 7 | 02-12-2008 05:11 PM |
