Go Back   DMCTalk.com forums - A DeLorean Community > Main Forums > General DeLorean Discussion
General DeLorean Discussion Tech help and certain general discussions of the DeLorean, DeLorean Motor Company, and John Z. DeLorean.
Old 01-08-2010, 03:52 PM   #1
bob_hunley
New Member
Default Accelerator - Sensor Plate
My car starts fine, idles fine, but the accelerator does not pull the sensor plate down. If I manually press the sensor plate down the engine revs great. Is there a vacuum line that could be shot, cracked, or disconnected?
Thanks for any helpful suggestions.
bob_hunley is offline   Reply With Quote
Old 01-08-2010, 04:47 PM   #2
Patrick C
DeLorean Owner/Aficionado
Patrick C's Avatar
VIN: 1880
My Club: DCO
Default Re: Accelerator - Sensor Plate
Are you sure the throttle cable isn't snapped? Does pressing the gas pedal do anything at all?
Patrick C.
Vice President, DeLorean Club of Ohio
VIN 1880
See my polished stainless finish==> http://www.youtube.com/watch?v=Us02zx86KYQ
http://www.cardomain.com/ride/2239767/1
Patrick C is offline   Reply With Quote
Old 01-08-2010, 05:14 PM   #3
bob_hunley
New Member
Yes, I am sure the throttle cables are fully functioning. To clarify my earlier statement, the car starts fine, idles fine but when you depress the gas pedal, it kills the engine. So, it is as if some vacuum line or something having to do with the throttle position sensor is shot. I am not a mechanic - just passing along what is being observed.
Old 01-08-2010, 05:52 PM   #4
Bitsyncmaster
Bitsyncmaster's Avatar
VIN: 03572
FYI:
There is no throttle position sensor. The only thing the gas pedal does is open the butterflies between the W pipe and the mixture unit.
Sounds like your mixture adjustment is way off. That could be the WUR, lambda, primary pressure or a large vacuum leak.
Is your frequency valve buzzing at idle?
Dave M
vin #03572
Bitsyncmaster is offline   Reply With Quote
Old 01-08-2010, 06:03 PM   #5
Matthew
Matthew's Avatar
Sounds like the plunger in the fuel distributor is sticking. Is it hard to press the plate down manually?
Matthew is offline   Reply With Quote
Old 01-08-2010, 07:26 PM   #6
Ron
Ron's Avatar
VIN: 01669
My Club: SEDOC
Check this out. See if 23 & 25 move when yhre pedal is pressed.
Ron is offline   Reply With Quote
Old 01-08-2010, 08:02 PM   #7
jtrealty
Delorean Guru
jtrealty's Avatar
VIN: 10757
My Club: DMA
The motor should die when you manually depress the air sensor plate. If it instead revs up that would mean you have a massive air leak. The throttle is not directly connected to the air sensor plate.
David Teitelbaum
jtrealty is offline   Reply With Quote
accelerator, sensor plate
[Fuel & Emissions] O2 Sensor delorean502 General DeLorean Discussion 6 05-06-2009 09:33 PM
[Engine] TDC sensor Bitsyncmaster General DeLorean Discussion 8 04-16-2009 09:50 PM
[Fuel & Emissions] Air intake sensor plate -- pressed down Beachdrifter General DeLorean Discussion 22 10-12-2008 01:22 AM
O2 sensor trouble Darkzygote General DeLorean Discussion 26 06-25-2007 04:29 PM
Oil Pressure Sensor nofear365 General DeLorean Discussion 8 02-14-2006 10:56 AM
