Go Back   DMCTalk.com forums - A DeLorean Community > Main Forums > General DeLorean Discussion
General DeLorean Discussion Tech help and certain general discussions of the DeLorean, DeLorean Motor Company, and John Z. DeLorean.
Old 12-27-2009, 03:58 PM   #1
tiger38117
DeLorean wreck survivor
tiger38117's Avatar
VIN: 1905
Default Unhooked door rod
Today, I was inside my driver's door getting my window back on track (success!) and noticed that one of the rods in the door mechanism is disconnected and just laying there. The rod in question goes rearward from the bell crank and moves back and forth when the door is locked/unlocked. And oddly enough, my doors work perfectly, they latch/unlatch and lock/unlock as they should...hard to believe if something is unhooked.
I can't find a good diagram of the lock rods in the service manual and can't tell where this loose rod is supposed to hook. Anyone have a good diagram I can look at?
Thanks,
Scott
VIN 1905, frame number 1380, gas flap, black interior, 5-speed, dark wheels, windshield antenna, perfect door alignment with no door guides, as pretty underneath as on top
tiger38117 is online now   Reply With Quote
Old 12-27-2009, 04:11 PM   #2
jtrealty
Delorean Guru
jtrealty's Avatar
VIN: 10757
My Club: DMA
Default Re: Unhooked door rod
Sounds like the locking rod to the rear door latch. You are right, you would not notice any difference in operation, the front door latch will still lock and prevent the door from opening. You are right again, there is no good picture. You could try opening the other door and looking inside.
David Teitelbaum
jtrealty is offline   Reply With Quote
door latch, doors, locking rod, rod
[Electrical] Two door switches on driver door Mark W General DeLorean Discussion 9 06-25-2009 06:46 PM
New door lock actuators, door lock module, remote trunk release DMage General DeLorean Discussion 32 06-29-2008 04:55 PM
driver's door stuck, passenger door okay Farrar General DeLorean Discussion 10 12-26-2007 05:56 PM
To open the door, you must be smarter than the door Manntis Open Discussion 3 05-14-2006 10:04 AM
Powered by vBulletin®
